05 F250 6.0 96K Miles, 1/4 throttle stumble - Ford Powerstroke Diesel Forum
Old 02-23-2013, 07:51 AM
Just wanted to pick your brains on my truck.
05 F250 96k and is all stock except for a MBRP Exhaust with no cat. Its pretty much ran ruff and hard to shift when cold for quite awhile. I usually let it warm up for a bit before driving it.
Recently, the truck has developed a stumble while driving say 40mph at 1/4 throttle. The truck stumbles then clears and u can see a puff of blue smoke in the passenger mirror.
stuck injector? Clogged EGR ?
Where to start to try and diagnose ?
TIA !
Old 02-23-2013, 07:54 AM
Yes either a stuck injector or egr... Try pulling the egr valve and cleaning it first and see what happens.. If not go to the dealer and get them injectors tested on IDS.
Old 02-23-2013, 07:56 AM
Sounds like possible stiction what weight oil you running
Old 02-23-2013, 08:04 AM
Valvoline Synthetic 5w40 since 30k miles Awhile back I ran some Rev-X (with no improvment to rough idle on cold start/blue smoke)
