turbo noise? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-25-2007, 08:00 PM Thread Starter
turbo noise?
well i made it to see my brother in wv for christmas and i had to show him my truck( or show off my truck i should say) i ran it hard a couple of times up to about 60 or so from a stop just to show him how good the truck was on the performance tune. the egts went to about 1200 and then i took it easy for the last mile or so till we got back to his house. i sat in the driveway and let it idle till the egts came down to 350 then turned it off. we went inside for a while and then when i left i noticed when i gave it 1/4 throttlle and boosted up to 15 and then let off the gas there was a flutter or something coming from the turbo. you can also see the turbo needle jump with the sound of the flutter as its comming down. its never done this before so i dont think its the turbo fart i here about. i cant imagine that i tore the turbo up that easy. is there something else it could be. has anyone had this happen before?
2004 Ford King Ranch
Crew Cab Dually
Chestnut Metallic
6.0 Diesel
PS2 with Customized Caddy
MBRP 4" Dual Exhausts
Zoodad Mod
Cat Delete Pipe
ARP Headstuds
Muffler Delete Pipe
ISSPRO Enhanced Visibility White Faced Blue Pointers
Boost, Pyro, Trans, Rear Diff
SCT LIVEWIRE(custom tunes later)
Mismatched Camper Top
:burnout
ncbowhunter is offline
post #2 of 9 Old 12-25-2007, 08:15 PM
DoubleDpsd's Avatar
That's my definition of turbo fart. But according to your sig you have the stock intake and you shouldn't get turbo fart with a stock intake. hmmm...that's all Im worth. good luck. merry xmas.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 9 Old 12-25-2007, 09:16 PM
I have a stock intake, and mine farts all the time when it's cold and occasionally when it's warm too. It usually does it after getting on it hard.
2006 F-250 Powerstroke Crew Cab Lariat Long Bed 4x4 FX4
SCT Xcal2 with Xtreme tunes by Innovative
Banks Monster Exhaust/Quadzilla Commander
ARP Head Studs and Elite Sneaky Pipe (Thanks Scuffy)
tech10002 is offline
post #4 of 9 Old 12-25-2007, 09:21 PM
KILLER KEN's Avatar
MINE DOSE THE SAME THING HOT OR COLD. THERE IS NO BLOW OFF VALVE ON THE 6.0. ITS NORMAL.
2004 F350 CREW CAB SHORT BOX 6.0 5 SPEED AUTOMATIC 4X4 SRW WITH CAP FOR WORK, A TICK UNDER 9000 LBS. K&N COLD AIR KIT, SUPER CHIPS 1805 IN PERFORMANCE MOST OF THE TIME. 305/65R16LT TIRES. RAN 14.83 IN EXTREME MODE IN 4X4
KILLER KEN is offline
post #5 of 9 Old 12-25-2007, 09:33 PM
KVFD
redstroker_2002's Avatar
well i am glad my 7.3 doesnt do that
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #6 of 9 Old 12-25-2007, 11:23 PM
Yeah, it's a pretty crappy design on a $14k engine--isn't it.
post #7 of 9 Old 12-26-2007, 05:21 AM Thread Starter
yeah stock intake, but its funny that ive never heard it before. ive had the truck two years and its not done this before. could it be a inter. boot or y pipe? im also assuming that an aftermarket intake makes it more noticeable? the truck seems to be running fine-still boots to about 28-30. does seem like the egts are a bit higher and it comes down more slowly than it did before. if this is normal do we just live with is there something that will eliminate this?
Crew Cab Dually
Chestnut Metallic
6.0 Diesel
Zoodad Mod
Cat Delete Pipe
ARP Headstuds
Muffler Delete Pipe
:burnout
post #8 of 9 Old 12-26-2007, 11:35 AM
They don't generally do it when they're new. Mine didn't do it when I first got it either. It was about a year old then. It started a few months ago. It sucks, but it's normal. Changing the turbo with a brand new one will virtually eliminate it, but it will come back in time. I think the aftermarket turbos don't do it much at all. Ford even has a TSB that mentions it that says it's normal. I think it's a problem with the stock turbos, but Ford just doesn't want to admit it so they don't have to replace them.
It's a lot worse when it's cold when the VGT vanes tend to stick, as you've noticed.
post #9 of 9 Old 01-14-2008, 10:38 AM
i think my truck started doing the same..when i let of the gas, the engine makes a chopping, chukkle sound and im not sure what it is..it only does it when i let off the gas..the engin runs fine and start fine aswell, any suggestions
timsandoval is offline
