NEED HELP ASAP!!!!!!!!!!!!!!!!!!!!!!Asking all 6.0L pros - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-21-2013, 05:10 PM Thread Starter
2000-7.3L's Avatar
Feedback Score: 10 reviews
2005 F5506.0L
replace camshaft sensor and crankshaft sensor and now wont start. Anyone please help me, need this trUck for the AM
Any ideas?????????????????//
2000-7.3L is offline
post #2 of 10 Old 02-21-2013, 05:14 PM Thread Starter
2000-7.3L's Avatar
keeping it ontop, comon guys i need help ASAP
post #3 of 10 Old 02-21-2013, 05:33 PM
bondsman's Avatar
You need a sanner to determine what codes it is setting. What are the symptoms other than not starting? Is there smoke coming out of the exhaust while cranking? What happened when it shut off? Kinda hard to troubleshoot via forums with the only information being it won'tstart.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #4 of 10 Old 02-21-2013, 05:45 PM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
Did you check FICM voltage?
MIKE
2016 Tow Boss
mudrunninpig is offline
post #5 of 10 Old 02-21-2013, 05:46 PM Thread Starter
2000-7.3L's Avatar
no codes, no smoke on cranking
post #6 of 10 Old 02-21-2013, 05:59 PM
bondsman's Avatar
You can unplug the ICP sensor to see if it will start.
No smoke while cranking..
Is the fuel pump turning on when you turn the key on?
Are all of your fuses good?
STC fitting could have blown as well as torn orings on the standpipes/dummy plugs.
HPOP died.
IPR trashed.
There are a LOT of things it could be and throwing parts at it is not the best way to diagnose. First thing would be to get a scanner and pull the codes. Hopefully there is someone near you with AutoEnginuity that would lend a hand and check your high pressure oil system, ficm, injectors and anything else to figure out where your issue is.
Post up your location and someone close might chime in.
bondsman is offline
post #7 of 10 Old 02-21-2013, 06:03 PM Thread Starter
2000-7.3L's Avatar
HPOP died.
IPR trashed.
All of that caused by just changing 2 little sensors
Milford, NH
post #8 of 10 Old 02-21-2013, 06:17 PM
bondsman's Avatar
It ran before you changed the sensors? Why would you change the sensors? Check the connectors. Check the fuses..
bondsman is offline
post #9 of 10 Old 02-21-2013, 06:21 PM Thread Starter
2000-7.3L's Avatar
ran rough before i changed them
post #10 of 10 Old 02-21-2013, 07:23 PM
pizalm's Avatar
Do you have a scanner to check for ficm sync? My truck had a couple strange no start episodes where it had lost ficm sync out of nowhere. No smoke cranking and just the odd half sputter now and then.
pizalm is offline
