Is filling your tank at half a bad idea? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-21-2013, 12:45 PM Thread Starter
Quoted: 4 Post(s)
I have a 2004 6.0 and ever since I have gotten it, I have filled up when my tank is at half. Ever since then, my fuel pump got damaged and all of my injectors had to be replaced. Are my tank filling habits to blame?
joejack6.0 is offline
post #2 of 5 Old 02-21-2013, 02:05 PM
Quoted: 48 Post(s)
has nothing to do with it
drunk on diesel is offline
post #3 of 5 Old 02-21-2013, 02:16 PM
lol I run mine on a 1/4 all the time! ... and sometimes down to E... All is well
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #4 of 5 Old 02-21-2013, 02:36 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
No, it has everything to do with you having a weak fuel pump for a long time. The weak pump junked your injectors. Refer to your first post here, 6.0 Engine Block Heater. A fuel pressure gauge would have probably saved your injectors.
dhanna6powerstroke is offline
post #5 of 5 Old 02-24-2013, 07:28 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I keep my tank as full as possible just for the 340lbs, it rides better with a full tank.
I went as far as dropping my spare tire down drilled two 4" holes in the sidewall and managed to get 400+ lbs of concrete in the tire. Cranked it back up and locked it in with some 3/8 chain through the frame, you would be surprised how much better it rides because of that weight. Been thinking about welding a 3" pipe at the hub hole so I can fill concrete into the wheel too, figure 200lbs more would ride even better. Truck weighed 8640 empty. lol
As far as you fuel level goes it doesn't matter like the guys said but; it is possible you had some bad fuel and the trash settles to the bottom of the tank and you may have plugged up the fuel filters bad enough to have fuel starved the injectors. Or as simple as a bad fuel pump or regulator or even all three possibilities.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
