Edge Juice Problem
04 Juice problem. Its been working fine then egt was only reading ambient temp and then monitor went out and I got a check engine warning. Engine stalled and when I removed the juice everything was ok. Sent it back for repairs it came back and same problem. Edge said it was s internal edge problem and sent me a new one. Same problem with the new one. Engine code was turbo boost high circuit warning. Anyone have the same problem?????http://www.powerstroke.org/forum/ima...ilies/ford.gif
edge problem
Went back and forth quite a few times with edge. They were very helpful and the problem was finally solved. My truck was "flashed" by the ford dealer for a high pressure oil relay failure. This basically made my trucks computer think it was an 2007 truck. My version or the edge was not compatible with and 07 even thou the truck was really an 04. Edge ended up upgrading me to the newest version (which was quite a bit pricier than the one I had for free), all new components. Working great now, no problems since the changeover quite a while ago.
How did you find out that it was flashed? |
edge
Actually the truck was runing like crap, no power at all after I got it back from ford. I had taken the edge off to have it in for service. Took it back and they said they had to reset the computer. I guess that was the flash. Did you take your truck in for any service lately?
