06 80k mile f350 diesel has leak in up-pipe to turbo?
our 06 F350 that has has a 4" silverline exhuast on it since 35k miles, suddenly had a major exhaust leak, i thought it was the plate blockoff where the EGR used to be hooked behind the engine, but it wasnt. its the flex pipe part apparently is cracked and leaking a ton of exhaust out, causing the turbo to not have adequate pressure to build boost well, also has a huge whistle now too.
shop said it would be roughly $850 to replace/fix. I've heard of a ton of various problems, stuff guys break on these trucks, but how on earth is this part broken? The truck's exhuast looks flawless otherwise, even behind the manifolds, where the flex is, isnt rusty or anything, isn't this part stainless?
could we have damaged it when removing the EGR 14,000 miles ago/almost 2 years ago? nothing was done to the truck engine/exhaust wise since then.
I had a SCT tune on it for some of that time, but had since uploaded the factory tune months ago when my guys would be driving it around plowing snow in the winter months or mainly driving around spreading salt in NJ lol.
I swear the stupid bullsh1t with the diesels, no wonder everyone is buying the gas motors now, if its not the common stuff, the oddball stuff kills you too. Our other 06 dually with ARP studs, turbo, tune, etc, now is losing a ton of coolant each week, not burning it so has to be leaking it in a hose or radiator.
