6.0 motor running ruff, not starting when warm - Ford Powerstroke Diesel Forum
Old 02-17-2013, 10:56 AM
I have a 04' f250 with a late 03' 6.0 motor in it. It has an egr delete an i replaced the irp sensor. Its running ruff and will not start after its warmed up until i turn the key on/off several times. I know i need a injector an i want to stay with stock injectors. where can i find good priced stock injectors? The second question is could the dummy plugs be bad, Is that the reason why it won't start after its warm?
Tags
dummy plugs, injectors, not starting, running ruff
