Cps code after washing....no go above 1800 rpm - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-15-2013, 11:01 AM Thread Starter
Strokergonebroke's Avatar
2004 6.0.
Tool the truck to the dirt like i've plenty of times, washed her right after like i do everytime.
This time tho im gettin a cps sensor code and she will not go above 1800rpm at all...bucks and says "no sir i wont".
No smoke, starts and drives at 100% until 1800rpm...
Were is the cps located(picture would be awsome) and what do you guys think could be causing this? Im assuming water on plug or shorted wire.
Thank you
Strokergonebroke is offline
post #2 of 4 Old 02-15-2013, 12:21 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
what is the code#
Check your ICP it's either on top of pass valve cover or under turbo depending on month of build.Water could cause it to do that dry it out.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 4 Old 02-15-2013, 01:25 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
A CMP code? Chances are it's due to excessive cranking or moisture in the plug at the sensor. Left side of block near the front.
Page 10: Component Locations
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 02-20-2013, 06:16 AM Thread Starter
Well the cps sensor about crapping out
Died in the parking lot, had to take a screw driver and give it a licking and she fired back up.
Thanks guys
2004 6.0...studded,sinister coolant filter,updated turbo lines,oil cooler,fuel spring,egr delete, 6in lift, 37 military tires, looney'd and podded.
