Oil loss? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-15-2013, 09:07 AM Thread Starter
Jack Lester's Avatar
Quoted: 3 Post(s)
Oil loss?
I have a 06 6.0 deleted studded oem gaskets. I started loosing coolant around the exhaust manifold on passenger side coming out where head meets the manifold. Also down half way on oil dipstick with just 300 mile on oil change. Please help.
Jack Lester is offline
post #2 of 9 Old 02-15-2013, 12:06 PM
Any smokeing? Mods other recent repairs Codes etc What have u allready checked.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 9 Old 02-15-2013, 12:10 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I'd check the small coolant hose that goes from your oil cooler to you EGR delete. That's the most common spot for the leak.
dhanna6powerstroke is offline
post #4 of 9 Old 02-15-2013, 12:20 PM Thread Starter
Quoted: 3 Post(s)
Oil loss
Thanks dannyboy950. I have had the heads done and studded bout 300 mile ago haven't noticed any smoke it's back at the shop where or was done. The shop said they had the heads trued up checked for cracks. I have a feeling it'll be my fault some how. I did have a air pocket on the system when I switched my coolant over from what they had in or. It whistled through the cap then burped and was fine no spike on the temp gauge. I had the bottle full to the top when it burped it went to normal operating level. I had straight water in it when this occurred.
post #5 of 9 Old 02-15-2013, 12:27 PM Thread Starter
Quoted: 3 Post(s)
Oil loss
Thanks dhanna6. I can see antifreeze coming from the very back of the manifold where it bolts to the head when it's running it foams out and spits it out also mainly bubbles out around the manifold.
post #6 of 9 Old 02-16-2013, 09:26 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
Are the manifold bolts tight?
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #7 of 9 Old 02-16-2013, 07:42 PM Thread Starter
Quoted: 3 Post(s)
oil loss
the bolts on manifold are tight just waiting now to see what the shop has to say. i'm sure it won't be their fault.
post #8 of 9 Old 02-16-2013, 07:49 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
the shop may have not added enough oil when the studs were done. on a bone dry system you need 16-17 quarts, not the standard 15qts on a normal oil change
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #9 of 9 Old 02-16-2013, 09:29 PM Thread Starter
Quoted: 3 Post(s)
oil loss
thanks for the reply sinner6.0 i checked the oil right after the studs were done and it was full. i noticed the oil loss after i noticed the coolant leak from around the manifold the oil was down half way on the stick with only bout 300 hundred miles on the change. i'm confused where its going. more input please.
