am i forgetting anything - Ford Powerstroke Diesel Forum
Old 02-12-2013, 12:37 PM
so I am doing arp head studs and egr delete and rebuilding my turbo also doing new oil cooler with the coolant filter on my late 04. can anyone think of anything that I am forgetting to do while I have this thing all ripped down. I have had nothing but problems with this thing so I am giving it one last chance before I trade it in thanks for any advice
Old 02-12-2013, 02:34 PM
Get new dummy plugs and an updated stc fitting, also the updated standpipe, while you have her torn down that far, ICP sensor wouldn't hurt either, at least clean the screen or install a new screen kit.
Old 02-12-2013, 04:21 PM
thanks I will order that stuff right now I was thinking that I forgot some stuff and just wanted to double check thanks again
Old 02-12-2013, 06:28 PM
You mean ipr valve* icp is on the valve cover and has no screen on it. Also the 04.5's did not have a stc fitting... If you really want to have peace of mind, replace the hpop. You wont have to touch it again after that
Old 02-12-2013, 06:30 PM
So yes, get a new updated screen kit for the ipr valve(valve mounted on hpop, next to turbo)
Old 02-12-2013, 06:32 PM
also, the oil cooler service kit comes with a reservoir screen.
Old 02-14-2013, 08:56 PM
Ok so i got all the parts ordered i was just wondering if i should do the low pressure oil pump to while i am at it.thanks for the info
Old 02-15-2013, 12:53 PM
Fuel it up again Dummy
Not unless its a problem
Old 02-16-2013, 06:26 PM
Where did you order your stc fitting and stand pipe?
Old 02-23-2013, 07:17 AM
I got everything from xdp
