So now what did I do wrong - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-10-2013, 03:11 PM Thread Starter
I replaced the FICM because truck would not run. New FICM truck started right up but had dead cyl #3. Replaced the #3 injector and now truck runs on 8 but you have to crank it until it shows pressure on the gauge before it will fire. Once running it seems to run fine although I have only driven it around the block. Appparently I created the problem because it started fine before replacing the injector. This might help, 2004 F350 6.0
agoura2327 is offline
post #2 of 8 Old 02-10-2013, 03:47 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
You have air in the HPO system. You need to drive it for a while to bleed it out, and it will be fine.
toren302 is offline
post #3 of 8 Old 02-10-2013, 04:01 PM Thread Starter
OK I will get brave enough to drive the thing around for a while. I just want to get this thing running well enough to get rid of it. This particular series has been going on for two months. Every time I Fix one thing something else goes wrong, I order more parts and find more time to play mechanic. When I thought that I had now somehow created the starting problem I was on the verge of road testing the fire insurance. I can only hope that you are correct.
post #4 of 8 Old 02-12-2013, 02:12 AM
PHYRMN's Avatar
What was the outcome?
PHYRMN is offline
post #5 of 8 Old 02-12-2013, 06:13 AM Thread Starter
Drive it for about 10 miles and it is now starting and running fine.
post #6 of 8 Old 02-12-2013, 02:41 PM
Pistolgrip426's Avatar
That is common when the hpo manifold is removed, gotta purge all the air out, sounds like you got it figured out.
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
post #7 of 8 Old 02-12-2013, 06:07 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
playing mechanic?! I take offense to that!
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 8 Old 02-12-2013, 07:18 PM Thread Starter
No offense intended, I grew up in my fathers auto repair shop and spent the first 20 years of my full time employment repairing everything from motorcycles to the occasional class 8 truck. I found out two things about auto repair I am very good at it and I hate it, but I do know how talented you need to be to be good at it.
