Rear main seal install - Ford Powerstroke Diesel Forum
Old 02-10-2013, 12:14 PM
Has anybody installed a rear main seal without the Ford tool? If so how did you do it and did it leak. I am finishing a cam install and down to putting the rear main in and the motor is ready to go back in. Thanks for any help.
Old 02-10-2013, 12:37 PM
Powerstroke Techie
Feedback Score: 3 reviews
good luck, the new rear main has a wear sleeve that must be pressed on the crank at the same time the seal is pressed into the rear cover.
Old 02-10-2013, 12:40 PM
I kinda figured I would need it. I guess I will hit up my neighbor, he is the parts manager at a Ford dealer, he got me the tool to align the cam and crank so hopefully he can get me this tool.
Old 02-10-2013, 12:51 PM
Powerstroke Techie
that is the way to go for sure. do you want the tool number? it should be in the same kit as the cam tool
Old 02-10-2013, 02:35 PM
Did Ford ever get away from that plastic tool back to a real TOOL?
Old 02-10-2013, 04:28 PM
I came up with OTC#303-770.
