05 6.0 just died!
I had been moving equipment and went to get stuff for Valentines Day and decided to run through the automatic car wash and when I went to pull out on the highway it just died. There was no lights, or warning at all. It kept showing something fault. I was to mad and aggravated to remember what it said. When Id turn the key on to start it, everything looked normal but it would barely crank and wouldnt crank enough to start it. The washer fluid would squirt the entire time the key was on and if I turned the wipers on, they would barely move. So I had it towed to the Ford dealer where its always been worked on. Who knows what this will cost me!
With that being said I have had zero trouble with the motor other than the turbo was replaced under warranty. Its only got 72k on it and a cold air intake and 4" exhaust. I am just lost as to what it could be? Any help would be appreciated.
