6.0 head bolts and gaskets - Ford Powerstroke Diesel Forum
Old 08-14-2006, 05:23 PM
marc,got a egr cooler replaced.eng is still blowing coolant out the d-gas under load,head gaskets ?i called arp about studs $500.00 wow.have you heard anything about ford inproving head. bolts or gaskets.and would ford void the warentee if i have arp studs installed? if i can get them there back orderd 145 sets.
Old 08-14-2006, 05:25 PM
is it overheating at all???
Old 08-15-2006, 04:03 AM
it is not over heating.no coolant in the oil.has the dgas tank sticker recall
Old 08-15-2006, 06:54 AM
ill try to explain further when i get home from work, but i seriously doubt its headgaskets then...
Old 08-15-2006, 07:18 AM
Marc,don't want to go against any of you suggestions,but ,When mine went out I drove it from New Jersy to B.c. on the west coast and the only overheating I had was up long hills .and I was pulling my 15k 5'er.
used only 4 gallons of anti freeze the whole trip.
Old 08-15-2006, 08:53 AM
Go against?? nah man, this is completely open for discussion, post away!!! i know as well it could still be headgaskets, but since he just had an EGR cooler fail, i have seen oil cooler passeges get plugged afterwards causing coolant restrictions, which causes a purge from the cap since the water up there boils, even though the motor temp stays consistant....
Old 08-15-2006, 07:42 PM
i dont think the egr cooler was bad,but it was changed to elemenate it from the equaishion.what to have them do next?all under warentee.
Old 08-16-2006, 06:12 AM
tell them this, a buddy of yours is a tech, and he said that the EGR cooler should be checked agian, and it should be driven watching EOT (engine oil temp) and ECT(engine coolant temp)......if the two are not withing 25 degrees of each other after full warm up, the oil cooler is plugged.....I hate hearing about heads coming off trucks because a lot of them were not the problem to begin with.....I would say 60% of the time dealers do headgaskets, it wasnt the problem....
Old 08-17-2006, 01:58 PM
marc,i checked the temps today...coolant 185...oil 235.eng ran 40min before scan.how does a pluged cooler tie in with d-gas presher leak?it also makes a weard whistle noise,preasher out the cap ? thanks john
Old 08-17-2006, 02:16 PM
Marc ,if you get this whistle noise solved,please post the results.I,yesturday had 3 customers call with this same issue. I'm bettin on exhaust leak or turbo.
