HELP - puking coolant and no heat ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-05-2013, 04:13 PM Thread Starter
Question HELP - puking coolant and no heat ?
My 2004 6.0 occasionally pukes coolant from the coolant cap and now it will switch back and forth from making good heat to blowing cold air . The thermostat is new ,the coolant cap is new and the heater core has been flushed. Are the puking and heat issue related or two different problems ? It has a sinister full egr delete that has been on it for a couple of years so its not the egr cooler. Any advice anyone can give would be appreciated .
redsoxguy is offline
post #2 of 6 Old 02-05-2013, 07:03 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Odds are you have a head gasket issue, combustion gasses will go to highest part of cooling system (heater core) and puking is the other trait.
Being it has no egr cooler, looks like head gaskets........bum deal check it with strips or pressure gauge to confirm.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #3 of 6 Old 02-05-2013, 07:31 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
textbook head gaskets.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 6 Old 02-06-2013, 03:32 AM Thread Starter
Thats what i was afraid of. What does that cost ? $3000? $4000? I was offered $ 8000 trade in on it last year. Doesnt seem worth spending half what the truck is worth to fix it. How long before it implodes if i keep driving it ?
post #5 of 6 Old 02-06-2013, 04:55 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Well the longer you let them go the better the chance the heads will need replaced. I've seen gaskets that were obviously leaking for a long time and the cylinder head surface was completely deteriorated around the fire ring. Not even a mill could have saved the last set I saw.
-Matt
2015 F-250 XLT 6.7L
post #6 of 6 Old 02-06-2013, 06:18 PM Thread Starter
Pretty good size snowstorm coming friday and saturday. This is my plow truck i will either make some money with it or blow it up trying and be farther in the hole.
