Whole truck is bouncing - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-05-2013, 08:47 AM Thread Starter
DT620's Avatar
When I first start up my truck and start driving it starts bouncing up and down. I recently got Matt's SRL and think it might be my oil isn't warm enough for the injectors at that point. Once my temps get a little Warner it stops and runs great. I could be completely wrong and any input would be great.
Sent from AutoGuide.com App
2004 F250 CCSB FX4
  • SCT w/ Matt's SRL
  • MBRP 4" turbo back straight pipe w/ 4" to 6" MBRP black tip
  • Edge CTS
  • Riff Raff Diesel intercooler boots
DT620 is offline
post #2 of 12 Old 02-05-2013, 10:13 AM
Are the rpms bouncing/fluctuateing or is the truck physicaly bounceing?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 12 Old 02-05-2013, 10:16 AM Thread Starter
DT620's Avatar
The truck itself is bouncing not the rpm's.
2004 F250 CCSB FX4
  • SCT w/ Matt's SRL
  • Edge CTS
DT620 is offline
post #4 of 12 Old 02-05-2013, 10:17 AM Thread Starter
DT620's Avatar
And it's only at 50 mph and up
2004 F250 CCSB FX4
  • SCT w/ Matt's SRL
  • Edge CTS
DT620 is offline
post #5 of 12 Old 02-05-2013, 10:23 AM
Odd! Could be teeth broke on the pinion gear or bad u-joint but that aughata make a lot of noise. Did you check your tires for aturned belt/damage?
post #6 of 12 Old 02-05-2013, 10:38 AM Thread Starter
DT620's Avatar
When it's warmed up it runs great and doesn't bounce at all. It's only when the temps are still low.
2004 F250 CCSB FX4
  • SCT w/ Matt's SRL
  • Edge CTS
DT620 is offline
post #7 of 12 Old 02-05-2013, 06:08 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
My truck is a bit bouncy when it's real cold it's worse. lol Once my 38" tires warm up and get round again it's fine, can't wait till summer
Sounds like you have a severe case of stiction, what oil are you using??
5W/40 will surely help but not so sure enough ? strange thread ??? ? ?
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #8 of 12 Old 02-05-2013, 08:08 PM Thread Starter
DT620's Avatar
I'm using Rotella T. I think it's 15w40 but not 100% sure, I'd have to check my bottles when I get home in the morning. I've thought about trying revx to help out and a fresh oil change.
2004 F250 CCSB FX4
  • SCT w/ Matt's SRL
  • Edge CTS
DT620 is offline
post #9 of 12 Old 02-06-2013, 06:54 AM
F250SixOH's Avatar
Switch to Rotella T6 5w40 and add revx. That should help
F250SixOH is offline
post #10 of 12 Old 02-06-2013, 02:07 PM
southend's Avatar
Re: Whole truck is bouncing
Come on......so stiction will make the truck bounce down the road, lol? I'd love to see a video of this.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
