need help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-03-2013, 02:28 PM Thread Starter
need help
have figered out ficm bad has 48.5 till crank goes to around 20 then comes back up after stop cranking with no start my ? is batteries check 12.5 when cranking goes to around 10 is that norm batteries are 6months old motercraft from ford dealer had them droped off and checked said they were good but on only had 725 cca is that normal or do they just not want to cover ,they have three year free replacment wondering if thats what burned ficm up how low should they go here s what they read
key off 12.5
key on glw plugs on 11.2
crank around 10
catt1173 is offline
post #2 of 3 Old 02-04-2013, 04:58 AM
need help
The battery voltage drop cranking is normal and you already know the FICM voltage drop isn't. The batteries tested "good" even though one was a little low on CCA (idk how low it would need to be for them to replace it under warranty) so fix the FICM. Is your battery voltage coming up to 14.4ish after 30 seconds or so running? If not you could have an alternator issue.
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #3 of 3 Old 02-04-2013, 06:34 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
we can't just replace batteries at will anymore. we have to hook them up to a charger/diagnostic tester and let it run it's course. It is going to try and recover the batt first and after that if it determines it's still not charging properly THEN it spits out a code and lets us warranty the battery.
you need a ficm by the way
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
