Turbo only working some times. - Ford Powerstroke Diesel Forum
Old 02-02-2013, 07:39 PM
I have a 2004 F250 with an EGR delete, and I just replaced a turbo boot that was busted, also changed oil and new fuel filters. When I let the truck warm up, in Park, I will hold it to the floor and it will go anywhere from 2500 rpms to 3000, but I never hear the turbo spool up. After driving it around it will start working.
Any ideas on what is causing this??
Old 02-03-2013, 12:13 AM
You could have restricted oil flow to the vgt or a bad vgt or stuck vanes/dirty turbo or too thick/heavy weight oil for your current weather conditions. any or all of the above.
Old 02-03-2013, 04:04 AM
If u have a monitor, check ur ebp pressure. I am having the same issue. Sometimes my ebp will stay at about 16 psi no matter what causing my vgt cycle to stay full open at 15%. I am about to pull the epb sensor and clean the tube hoping that will fix the issue.
Old 02-03-2013, 12:58 PM
Just changed oil to rosella 10w30 and we are having 40 degree to 70 degree weather here in south MS.
I have a spartan dash daq on my 08 f250 ill hook up and see if I can read the ebp
Old 02-03-2013, 01:26 PM
Fuel it up again Dummy
Take a look at the tubing going to the ebp sensor, may be plugged up with soot. On drivers side exhaust manifold switch is at valve cover height, tubing is 5/16 SS IIRC
Old 02-03-2013, 04:08 PM
Thanks, ill clean it out anyway.
Old 02-17-2013, 09:34 PM
Well I got a chance to clean the EBP Sensor, the sensor was pretty clean, but the tube was claugged in two different places, and the fitting that goes into the manifold was so packed up, I broke a screw head off screwing through it, took it out put it in a vice and took a nail and hammer to knock a hole through it. Bent the nail before it went through and got the broken screw off. After this the turbo works perfectly!!!
Just a helpful hint, brake cleaner doesn't do jack crap, only carb and choke cleaner worked.
Old 02-18-2013, 07:26 AM
Glad to see you got it running good, thanks for posting up the fix.
BTW next time you change your oil try going with a synthetic 5W/40 instead of (10W/30) Rotella/Mobil1/Delo400LE all make it and the injectors will love you for it, great cold start characteristics. Will perform at very low temps and up to 110 degrees IIRC, pretty much all temps here in the lower 48.
Walmart sells Rotella for around $20.00 a gallon by far the cheapest, I prefer the Delo 400LE for whatever reason it runs cleaner out of tailpipe leaves no soot on rear fender where the others do. They do claim it is a (LE Low Emission oil) but it does not soot up out the pipe like the others do..? Anyhow give that viscosity a try I'd be willing to bet you will never run anything else after you try it out.
Mark.....
Old 02-19-2013, 03:58 PM
Mark.....
Thanks for the heads up, I wish I would have took pics, but I have a 6.0 motor sitting outside that came out of my brothers truck to show everyone where it's located without all the clutter around it.
