No power...
Hey guys, I feel like I don't have the power I should have, I'm running Vivian's custom race tune, and mtw hybrid, my stock unison ring took a dump so I bought this hybrid, but without tuning I can get about 5psi and with tuning I don't get more then 17, I checked all my boots, all my exhaust clamps and gaskets and still nothing, when I first put the turbo on I couldn't spool it and found the nipple on my intake to be clogged so I just checked that again and it was still clean.. I'm kinda running out of ideas here and hoping maybe somebody has experienced this before and can point me in a direction.. I also checked my little boot coming of the turbo and it don't have any tears in it
Nobody?? I just replaced the map sensor and still no difference.. What kinda boost are y'all getting with these hybrids?
You should be able to get 25-30 psi depending on what gauge you have. I don't know if you have it, but the stock gauge or OBDll port only show up to 22.9. What is the VGT position doing? EBP partially blocked or leaking? Do you have a leak or bad connection in you up pipes to turbo? What is the back pressure?
I'm just using my cts, I'm gonna check my ebp tomorrow, I never thought about it, I checked all my connections and everything is tight and clean, no smoke around the connections
