i got stuck last night real bad worst than ever in my life---wanted to play but was too slick and truck slide in to deep hole--well long story short it had to spend the night in the mud....batteries are dead and im sure water got in to intake (air filter) 2006 f-250 6.0
so what do i do now---oil is clean but im scared to start the truck without proper procedure--- any and all help and similar stories would be appreciated!! tia mark |
Was the front totally under water?
Take the glowplugs out and turn the motor over, which will get all the water if there is any out of the motor. also if it went all the way under change the fluids, all of them.
front end was --lights under water-- cab on driver side had 2 inches of mud and water in floor---man i feel sick---
truck is lifted and runs 37's |
i had it running then turned it off when i tried to restart batteries were dead--battery lights had already come on and i wasnt thinking when i turned it off
I wanna see pics of the mud hole or lake you drove into.
Craig |
if the motor did get water in is it trashed now?
I wish I knew more but i don't want to tell you something that's wrong.
i dont know how to do glow plugs but im sure its a pain in the butt....
thanks guys---any more advice? |
for water to get into ur intake it has to go through ur tubro and ur inter cooler so check them for water and also change all the fluilds ever in the axle otherwise the limited slip will fix and wont work right
