injectors???? - Ford Powerstroke Diesel Forum
Old 01-31-2013, 03:06 AM
Unhappy injectors????
Last night i left work and my truck was idling funny, had weak accelleration and a rough vibration when it was in low rpm situations especially at 45-55 mph. If it is at high rpms there is no vibration. Its not smoking, there are no codes or lights on. Everything i read points to injector failure? The problem is consistent. Im just looking for some insight if you all would be so kind. It had a new ficm put in about 6 months ago but those symptoms were very different.
Old 01-31-2013, 03:07 AM
o yeah
03 f350 6l psd with 110k on it
Old 01-31-2013, 04:48 AM
you need to scan it/have it scanned with a device capable of reading manufacturer specific codes. regardless of whether or not the MIL is illuminated
Old 02-01-2013, 01:06 PM
Re: injectors????
Exactly what mine did when #4 quit fueling, replaced injector.
Sent from my phone that somebody didn't help me get.
Old 02-01-2013, 06:13 PM
southend
did it make you wanna take it out of overdrive cuz of the vibration?
Old 02-01-2013, 06:17 PM
Re: injectors????
It made me want to not drive the truck at all, lol. Very aggrivating, if I throttled down on it, it would go away, and come right back after I got back to cruising. Rough idle at the lights. You have a bad injector.
Old 02-01-2013, 06:24 PM
Re: injectors????
You need a monitor....Write Up: Monitoring the 6.0L PSD.
Old 02-01-2013, 06:30 PM
Re: injectors????
Here.......Why you shouldn't drive around with injector codes!
