oil pump and cooler replace...
is there anyone who can walk me through an oil pump and oil cooler replacement on my '04 6.0?
remove the turbo and the intake to get to the oil cooler with the intake off remove the front cover and oil pump and replace the front cover with the updated one
well
I'm guessing your out of warrenty. Did your oil cooler go out? What is the base concern here? Its a lot of work for someone that hasnt done it so lets get a grasp on the situation so we can better help you.
I have done it once and will be doing it again when my oil cooler gets in. Its pretty easy if you have been around engines for a little while. If you want I can take pictures while I do mine so you can see what all to do. The only scary part for me is there are some bolts that you have to thread into the oil cooler. Other than that its simply taking off stuff to get to it putting the new one on and putting all the stuff you took off back on!
