Head gasket ? - Ford Powerstroke Diesel Forum
Old 11-28-2007, 11:39 PM
Head gasket ?
I have installed these gages - engine temp, EGT, Trans, Boost. What are the early signs of a blow head gasket? What to look out for? Should I or should I not put a STC chip on my F250 04-6.0
Old 12-09-2007, 03:16 PM
Would a sign of the head gasket be going if there is preasure from the engine blowing coolant out of my resevor?
Old 12-10-2007, 06:28 PM
I'm not a mechanic, but from my reading and experiences it could be the egr cooler-oil cooler or the head gaskets. Hopefully somebody that knows more will answer you soon. There are a lot of threads on both issues. Good luck.
Old 12-10-2007, 06:31 PM
yeah that can be a sign, but that can also be egr related. look in the coolant just whith the engine running and watch for air bubbles
Old 12-10-2007, 09:31 PM
If I see air bubbles what dose that mean? The truck gos to the shop Wed.
Old 12-11-2007, 02:35 AM
That means air from the engine is blowing back into the coolant. Head is blowing or has blown. Also keep an eye-out for white smoke. That is caused by coolant leaking into the cylenders. There again head troubles. You may want to double check my info. I am not a tech but I try to learn as much as possible about my truck.
Old 12-12-2007, 10:11 PM
I'm still waiting on Ford. My truck is still there.
Old 12-14-2007, 08:35 PM
Head gaskets are blown. Ford is replacing the heads and gaskets. Mabey I'll get it back sometime this centry.
Old 12-15-2007, 09:22 AM
I was told that you should get ARP studs. Mine is in the shop right now getting them installed. I had to go to another dealer to . After my experiences, I wouldn't run any programs without them.
Old 12-15-2007, 09:24 AM
shes getting two new heads as well...both were warped 2-3 thousanths.....
