low boost??? - Ford Powerstroke Diesel Forum
Old 01-29-2013, 02:38 AM
low boost???
my boss has 3 of the 6.0's..........we got a problem with one of em right now,it dont have no power but idles just right .......in the shop if ya give it throttle and let off of it it sounds like a pop off valve through the air cleaner when ya let off the throttle .......now the mech. put his elcheapo scanner on it and no codes the only thing that came up is a low boost......any ideas???? my boss is freaking out and gonna sell em all ...........also when ya take it down the road it dose not have any power and struggles to get up to 40 mph.........hes wanting to go to all gassers and goverment motors (gm)
Old 01-29-2013, 02:42 AM
low boost???
Check all the turbo boots. One may have come off. Also check the intercooler inlet. I've seen it blow off before. Passenger side by the radiator. If you still hear the turbo spooling I think you're ok. You just have a leak somewhere.
Also, if the egr valve failed, or the o ring on it is bad, you won't have any power.
Sent from AutoGuide.com App
Old 01-29-2013, 02:51 AM
im not to 6.0 savy,i mostly work on heavy equipment ,where is the egr located at, the valve it self i mean........i got a 7.3 but i know these are a different monster
Old 01-29-2013, 03:01 AM
low boost???
It's to the left of the fuel filter housing. Has a wire harness going into the top of it. Probably a 2" diameter. I've had those o rings go out in me before.
I'm not an expert, or even close. Maybe some of the more knowledgable people will chime in soon with ideas.
Old 01-29-2013, 03:04 AM
thanks ,it gives me a place to start id rather do this than have him go to a gm.....hell i told him id do it on my free time to keep him from buying the other cough junk cough
Old 01-29-2013, 03:21 AM
low boost???
I hear ya. Some of these guys here are awesome at helping you diagnose issues. They'll be waking up soon.
Old 01-29-2013, 03:40 AM
Send a message via Skype™ to kendallcschm
I'm awake and happy to help! lol.. it sounds like intercooler boots.. but try taking the turbo apart and cleaning the veins as well.. they have a tendency to get clogged over time..
for the EGR you may need to get a pry bar under one of the ears to pull it out cause its in there tight
EGR location:
or here.. what the metal things are holding:
and this is the passanger side IC boot.. just remove that bottle if you have an F-series.. and it looks just like that.. its where the pipes come up for the A/C system:
Old 01-29-2013, 03:44 AM
thanks guys for the info.......im gonna go in early and take a look at it ........nice tongs????lol
Old 01-29-2013, 03:47 AM
LMFAO not my invention.. its 1puglife from youtube.. instead of using a pry bar the rocket scientist fabricated a set of egr removal tongs lmfao
Old 01-29-2013, 03:48 AM
could the egr valve itself be bad ??? and how to test it?? price for a new one if bad??? just askin so if he asks
