6.0 won't drive faster than 40mph spits and sputters blowing black smoke - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-28-2013, 01:21 PM Thread Starter
On the way back to South Carolina today my truck all of a sudden lost power and would barely make it pass 40mph. I was in the middle of nowhere at the time so I pulled over and as soon as I stopped it shut off. I let it sit for a couple minutes and started it back up after checking all the fluids. It started fine but would start shaking and hesitating at about 40mph at times blowing alot of black smoke. I drove it to the first exit and refilled the tank with diesel adding 2 STP fuel and injector cleaners to see if it would help but nothing. What do you guys think??
jrod0813 is offline
post #2 of 16 Old 01-28-2013, 01:37 PM Thread Starter
One more thing when my truck actually got up to 40mph the egt temp went up pass 1300*F. But then quickly went back down when I would let off the throttle.
jrod0813 is offline
post #3 of 16 Old 01-28-2013, 04:23 PM
yatespread's Avatar
Mine did the same thing when the ficm went out.
2006 Ford f350 King Ranch 6.0 4x4 c/c drw. BPD oil and egr cooler, DC Power 270 amp XP, muffler delete,Banks techni-cooler, Banks Ram Air filter, atlas 40, SCT Livewire
yatespread is offline
post #4 of 16 Old 01-28-2013, 04:28 PM Thread Starter
I hope it's something simple.. I dropped it off at a local shop in Florida and had to rent a car
jrod0813 is offline
post #5 of 16 Old 01-28-2013, 04:46 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Could be many things. Fuel pressure, FICM, injectors, HPOP, boost issue.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 16 Old 01-28-2013, 05:25 PM Thread Starter
The shop is saying that its probably the fuel pump but they won't know until tomorrow. I just serviced the truck last week but I didn't have time to change the fuel filters. I also hooked up an auxiliary fuel tank in the bed which I cleaned out before I installed but I'm think there might have been some stuff inside that I didn't get that might of clogged the filters up.. Just a thought
jrod0813 is offline
post #7 of 16 Old 01-28-2013, 06:16 PM
Term3's Avatar
Quoted: 2 Post(s)
Check for a stuck open EGR valve.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 16 Old 01-28-2013, 06:22 PM Thread Starter
A buddy of mine told me that he thought it was that. How hard is it to remove??
jrod0813 is offline
post #9 of 16 Old 01-29-2013, 07:16 AM
Term3's Avatar
Quoted: 2 Post(s)
In theory very easy, remove two bolts, unplug the wire connector, and then pull the EGR valve out. In practice it can take quite a bit to pop it loose. What I use is a 2X4 about five foot long, put one end on the top edge of the firewall, use some heavy wire looped over the 2X4 and through the two bolt holes of the EGR valve (you can easily rotate the EGR valve to gain access). Give it a sharp lift up on the 2X4 and your EGR valve will pop out like cork out of a champagne bottle. LOL
When cleaning the EGR valve do NOT get any solvent up into the head of the EGR valve or it'll be screwed.
Is that a satellite dish on top of your truck?
Term3 is offline
post #10 of 16 Old 01-29-2013, 07:25 AM Thread Starter
Yea that pic is old .... I've built a couple trucks after those 2... I'm going back down to Florida in a couple days I'm going to give this a try
jrod0813 is offline
