Oil leak under oil filter housing - Ford Powerstroke Diesel Forum
Old 01-28-2013, 10:44 AM
Have oil leak about 1 drip every 10 seconds. It is wet under filter housing, I removed it but there is oil everywhere. Reall does not look like filter housing leaking.
Is there anything else under oil filter that could leak
Old 01-28-2013, 02:17 PM
oil cooler cover probably.
Old 01-28-2013, 02:54 PM
There's an o-ring between the filter housing and the oil cooler.
Old 01-29-2013, 04:28 AM
pulled oil filter housing and it really does not look like it is leaking. So much oil that it could be though
Old 01-29-2013, 12:26 PM
I had an oil leak right behind the oil filter housing, it looked like it was coming from the oil pressure sensor which I replaced ($30 from the dealer) over the weekend. So far I haven't seen any oil marks in my drive way since...
