Engine jumps to 1K rpms - Ford Powerstroke Diesel Forum
Old 11-27-2007, 06:09 AM
Smile Engine jumps to 1K rpms
All,
Just noticed my 06 PSD recently started to run the idle up to about 950-1000 rpms, every now and then at idle. If I tap the gas pedal it will return to normal idle.
I assume this is normal but can someone confirm this is or that it happens to them???
Old 11-27-2007, 03:12 PM
Perfectly normal. It happens on start up if the temp is 50*F or below. It's like the high idle warm up feature on a gasser.
Old 11-27-2007, 03:34 PM
Just helps the truck warm up.
Old 11-27-2007, 05:04 PM
<<< 6.4 Powersmoke
oh ya normal. just means the truck is working properly actually. if it is just on start up.
Old 11-27-2007, 05:10 PM
yup...it should do it any time the oil is at air temp when its cold outside....
Old 12-05-2007, 04:18 PM
I find that even when hot, If I leave it idle for a while it ramps up. Could it be its for EGR cleanliness.
