Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 11-26-2007, 12:39 PM
jpeacoe jpeacoe is offline
Cool ICP Sensor???
I have an 04' 6.0 and I am wondering what is the best way to get to the ICP sensor. It is leaking badly and needs to be replaced. I appriciate any help!!!
Old 11-26-2007, 01:55 PM
npccpartsman npccpartsman is offline
Depends on the tech you talk to. Some like to do it from top--others from underneath. It is a pain (your is under the turbo right?) to get to. Maybe Marc or Scuffy will chime in with their favorite method. It takes a good tech about 30 minutes so it ain't quick, but can be done without taking apart half of the top of the motor.
Old 11-26-2007, 01:59 PM
Clay Henry Clay Henry is online now
Sooner Powerstroker Mod
You can reach it from the under side best. Can't really see it when you get an arm up in there though. 10 mm wrench to remove the heat shield and then theres the sensor. Mine went out and i didn't attempt to do it myself cause i knew how hard it was to reach.
Old 11-26-2007, 02:14 PM
Thanks!
Yeah thanks for your help I think i will try from the bottom. I will let you know how it goes!
Old 11-26-2007, 02:17 PM
The parts cost will eat you alive too. sensor AND wire harness if oil has infiltrated that.
Old 01-07-2008, 06:22 AM
Talking ICP Sensor!
I got it replaced! I worked from underneath the truck. The hardest part was the heat shield. I think it had like 3 bolts in it. Once the heat shield was off you could feel around and get to the ICP. Not hard it only took me about 30 min.
