Hey guys I'm new to this forum
Well I have a 2003 ford 6.0 My HPOP blew out on it about a month ago I had it replaced by Powertrain performance down here in Vegas But when I got it back he showed me and took pictures of how all 8 injectors go crazy and misfire only when you get around 1500 Rpms I've been getting help from a senior master mechanic from ford and he's been giving me test parts to try and see what it is but still nothing has worked I've replaced ICP,IPR,FICM, cam shaft sensor, map sensor, oh cant forget all 8 injectors are new, Wondering if anyone has had this problem, I really need my truck running its been down for almost a month and a half already
any codes being generated from the PCM?
i take it you've had a fuel pressure gauge on this while the issue occurs as well?
same question, any codes? a stuck open egr valve can cause multiple cylinder misfires as well |
and a code keep alive module or something comes up. ill check it when i get home |
Re: Misfiring only when warmed up
Subscribed
Sent from my PC36100 using AutoGuide.com App |
Fuel pressure? Air in fuel? I only ask because the original fuel pressure question wasn't answered.
Sent from my DROID X2 using AutoGuide.Com Free App |
try disconnecting the icp sensor. see if the problem persists. if it doesn't, it's probably the pigtail
