HELP, power steering - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-25-2007, 12:54 PM Thread Starter
lifetime member
Exclamation HELP, power steering
dad ,70 years old, put water in his power steering reservoir and drove app. 20 miles. how do i flush it and get it going again? 05 f 350 srw
january 2003 6.0 F-350 Lariat 4x4 cc with 08 long bed. recon cab and mirror lenses, torqueshift(reman on 9-03-09) with three disc billet convertor(500 rpm lowered stall speed),mag-hytec deep tranny pan,, 8" fabtech lift w/ 37" iroc super swampers on helos,pro comp ladder bars, custom sct x3 with tunes by eric @ innovative diesel, boost and pyro,edge insight, afe, 4" straight piped, ARP headstuds, banks intercooler & high ram intake. engine mods & maintenance by first coast diesel performance.
nsrchofpwr is offline
post #2 of 4 Old 11-25-2007, 01:04 PM Thread Starter
lifetime member
need help. bump,bump
post #3 of 4 Old 11-25-2007, 01:06 PM
this is a tough one to get out honestly....and will be messy. Look behind the bumper...you will see a small cooler. This is the PS cooler. disconnect one line from it....and put a drain pan under it. Let it drain as much as possible...then take about a quart of ATF and put it in the PS resevour and fire the truck up for a few seconds. Its gonna make a mess.....fill the resevour up and do this again. Do this about three times......honestly the pump might not make it after having water run through it. Make sure to drain as much water out of the resevour as possible before you start.....
mschn99 is offline
post #4 of 4 Old 11-25-2007, 01:32 PM Thread Starter
lifetime member
thanks. fluid is already milky. take top line or bottom off of cooler?
