Advantages of deleting egr cooler verses Bulletproof cooler
I just ordered the bulletproof oil and egr cooler and am wondering if I made the right decision on the egr cooler or should I delete it?
Re: Advantages of deleting egr cooler verses Bulletproof cooler
If you have emmissions testing that would be the only logical reason to have the bpd egr cooler. Otherwise delete.
Sent from my phone that somebody didn't help me get. |
I had no choice since the dealer did mine under warranty they would only do a real cooler so I paid for the BPD unit
now if I were to do it again I would use their delete and cut the bottom of and EGR valve and put that in the stock location for visual testing |
I am in FL. No problem with legal. I just wanted to know what are the advantages of deleting. I am not interested in a hotrod, I just want a reliable truck.
Great question! My "War Wagon" is getting ready to go under the knife and I am trying to decide which way to go. I have a BPD water pump on my truck and so far its worked great. BPD's customer service was top notch so either way I go I will more than likely go with BPD.
I did the bpd upgraded egr and now I wish I wouldnt have basiclly for 2 reasone. 1 it still allows the carbon and crud to get into your oil. Im looking into running a bypass filter and with out the egr pumpin in trash Id be better off but.... #2 you still have to clean and maintain the egr vavle itself. Not a huge chore but still ya gotta do it. If for some reason I gotta tear into the motor again Ill delete the whole mess.
when you think about the amount of particulate matter being pumped out of a diesel engines exhaust, it's easy to see that diesels were not designed to run egr without having a consequential effect on the engine. as we have all seen.
that being said, diesels produce extremely high levels of NOx under load. egr helps to offset these NOx emissions when it's most needed. what it really comes down to is; do you want what's best for your engine? or what's best for the environment? that, and the legality issues, of course |
When your EGR cooler leaks it will blow your head gasket. Truck runs cooler and gets about 2mpg better without it. Been installing delete kits for about 5 years and fixes one major problem with the Power Stroke.
