Bad fuel or bad injector or????? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-25-2007, 07:23 AM Thread Starter
I topped off my 6.0L the other morning at Wal-Mart, about 15 miles later the truck started running rough. It got so bad it died on the side of the road. It restarted and continued to run rough then normal and back to rough, max speed would vary from 30-75. When I got home I drained about a gallon of fuel from the filter drain with no water. We changed both filters with a few water particles around the engine mounted filter. I figured this would clear up the issue but it has not. It know runs for the most part ok, but idles very rough if its in drive at a stop light. You guys have any suggestions? I did add quite a bit of fuel supplement after this problem started.
Thanks,
Matt
helidr1 is offline
post #2 of 5 Old 11-25-2007, 07:43 AM
Jon
Guest
Posts: n/a
Quoted: Post(s)
runs rough
do you smell any gasoline in the samples?
post #3 of 5 Old 11-25-2007, 08:25 AM Thread Starter
No, i did not but it did look very yellow....
helidr1 is offline
post #4 of 5 Old 11-25-2007, 08:30 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Diesel has a yellow tint to it. Hmm did the ses light up on the dash?
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #5 of 5 Old 11-25-2007, 02:56 PM Thread Starter
no, no lights on the dash either!!!! There was water in the bowl on the engine fuel filter.
helidr1 is offline
