No Boost? Bad Turbo? - Ford Powerstroke Diesel Forum
Old 11-25-2007, 01:44 AM
Hey folks, first post here. I'm helping my Dad diagnose his truck, as he doesn't deal with computers (I don't do well either, but I can get by). It's an '03 F250 with 92k miles on it, majority of it towing a 36' 5th wheel (he's retired and did the full time rv thing for a bit). Totally stock, and he babies the thing. Only problems so far have been a vaccuum pump and a starter motor wise. I was at his house over the holiday and he was telling me how the truck lost alot of poop. We went for a ride, and as soon as he started it up, you can clearly hear a hissing sound, and when we get out on the road, you can't hear the turbo at all and the thing is a DOG, I mean he has it almost floored to get up to 50 mph, and it smells BAD, like a smokey old 8V71 Detroit. I think his turbo is bad, I can't see anything off under the hood (man, is it busy under there) He pretty much wants to know what it is before he goes to the dealer, as he has a $100 deductible and he hates dealing with them. Can anyone help me and my Dad?
Old 11-25-2007, 04:09 AM
Could be a loose coupling or something to do with the inercooler pipes???
Just a guess.
Old 11-25-2007, 04:33 AM
Definatley! check those real good and if you can get to the turbo easy, take the inlet tube off and check for play in the turbo and if it spins free.
Old 11-25-2007, 04:37 AM
Desert Shield/Storm Vet
The turbo vanes may be sticking also, and in need a good cleaning. If you have access to a scanner.....get it scaned for codes.
Old 11-25-2007, 07:01 AM
Chech the CAC hose (blue one at the turbo), it could have a hole in it, usually on the underside. Also, this is a "03". VGT has to be learned. Have the batteries gone dead lately ? If so, the only way VGT can be relearned without computer access (assuming their are no faults in the system) is to get the engine to operating temp and let it IDLE for 20 -30 minutes, a/c off, parking brake on. Just let it IDLE and don't touch the accelerator pedal. The "03" is a very fussy creature. I hope this helps.
Semper Fi,
Power Stroke Master Tech
Old 11-25-2007, 07:26 AM
say no to rolling coal
being as its not long for its warranty being up I'd definately take it in to a dealer you trust. $100 is a cheap fix and even if its something small you should be able to talk them in to at least cleaning your turbo for you. It might be a turbo problem as well and then you'd get a new one.
Old 11-25-2007, 01:40 PM
Ok, I forwarded this to him and he's looking into it. Is there any dealers in the Huntington Beach area that are good? Ones to stay away from will be helpful also.
Old 11-26-2007, 08:44 AM
I have had this happen and it was just the blue hose to the turbo starts to slip off. You cant tell until the truck is going. I took my clamp off, punched some holes in it to make it grip better and havent had a problem since
Old 12-05-2007, 05:04 PM
Ok, he took it in and he said they found an exhaust "Y" pipe behind the turbo is cracked. I'm not familiar with the 6.0, does this make sense?
Old 12-05-2007, 06:01 PM
yeah, makes sense.
