EGR cooler question - Ford Powerstroke Diesel Forum
Old 11-24-2007, 07:37 AM
EGR cooler question
My truck goes in on tue. for egr cooler replacement. I've been reading a lot of posts that say the oil cooler might be the problem. Just wondering if the dealer will know to check this also, or if I should make a point to tell them. They are covering it under warrenty. Have 41k on the truck.
Old 11-24-2007, 08:26 AM
Some dealers will replace both at the same time as they should be, however, some will only do it in steps. They should be able to hook it to IDS and see how much temp difference there is between coolant and oil. 20* higher engine oil temp is NORMAL. Anything more and the EOC should be replaced.
Old 11-24-2007, 09:10 AM
My dealer only replaced the EGR cooler. Now it's back in the shop. Hopefully yours replaces both or takes the time to do the test. Good luck.
Old 11-24-2007, 09:30 PM
do you have any problems towing like loss of power we can only change the oil cooler when changing the egr cooler if the differance between the eot and ect is more then 25 deg as per ford
