coolant loss and tea kettle sound.
well,...i gues it is time.
first i would like to say that this forum has been very helpfull and i did do a lot searching Things i,ve done in the past year is a coolant flush/backflush - restore only -cat ecl ec1 coolant - coolant filter - edge insight - SCT custom tune -fuelpressure meter & EGT meter.Car runs good and powerfull. Delta,s ECT 182/189 @65 miles. 6-7 i ordered a new stat & housing - blue spring cause i,ve noticed a fuel drop to 41 on w.o.t. last weeks i,ve noticed my coolant drops just a little bit i have added about a quart 3 weeks ago.Today i was on the german highways as you know there are no speed limits so i hammered it and after 10 minutes there it was...tea kettle sound when i was on the pedal,...when i got off it,..the sound was gone.So did a few bursts and sure it kept whistling. Opened the hood and it was a good 1 inch below the minimum mark (ps i filled up to minimum mark) what a bad time,...i need my car to drive to Spain in 5 weeks and back to the Netherlands 2625 miles round trip,...and do it twice.so 5250 miles. i do not think my precious ford will make it,now she,s sick. I could use some help. 1 remove egr cooler,...just weld it up and knock the scoop out or a IPR gen2 kit? 2 i think my delta,s are fine should i need a new oil cooler while i am in there? 3 How can i test if my HG are not leaking and be sure it is a leaking egr only? There are parts like Updated Hpop fitting - turbo downpipe - and all kind of o-rings and gaskets that i might need. i want her up and running reliable again...(well it does for now,but you know what i mean) before you throw parts at me,consider that parts are 2.2 times as expensive over here,...a friggin motorcraft oil filter goes for 39 euro,s elc coolant 160 euro,s... Luckely i am mechanicly enclined so i do not have to pay the stealership. sorry for the long post,..but i could need some help. thanx guys. |
Most EGR cooler failures come after a oil cooler failure, not before. However, it can happen. For the EGR cooler failure, you would see white smoke/steam out the tail pipe. To confirm this, park nose-low and remove the EGR valve. Inspect intake manifold for moisture. If you are still not sure, remove EGR cooler and inspect/pressure test. I don't have it, but I really like the IPR Gen 2 delete. I cut my scoop out and welded it smooth, but a simple plug for the V-band clamp would work (if you were keeping it to install a new cooler at some point). Quote:
Not too many trucks like yours in the Netherlands, nor X-stars either!
so true,...x-stars maybe 11 or 12.We do not have epic boats here.
i,ve heard those wakes are massive. p.s just sold my x-star,..and it hurts.But we are moving to spain. 84300 miles.. thanx for your info...i,ll search for that sticky Last edited by RiverSide; 01-24-2013 at 11:35 AM. Reason: miles |
i hooked up a psi mtr and i can not get 15 psi on the meter.
i did some 0 - 60 runs and did some highway testing. made a video,unfortunatly no sound,the cellphone mic is broken. I also removed the egr valve and it is wet/moist inside the intake. i cleaned the egr valve twice last 22000 miles and both times they where goey(sp?)but i thought it might be from the ccv.Today the valve was clean and shiny but i cleaned it just 2 weeks ago. i,m a bit lost,i want to order some parts but i do not know if i need HG. I removed the tune and go back to stock again. Last edited by RiverSide; 01-25-2013 at 09:25 AM. |
Your video is quite good, showing steady at about 8 PSI. It is highly unlikely you have a head-gasket issue. That is good news.
The moisture inside your intake is most certainly from a ruptured (but not too bad yet) EGR cooler. As you are probably aware, continued driving could result in catastrophic failure of the cooler and damage to the engine. Delete it or replacement it, your choice. You may want to order a new intake gasket, but it could be reused if it is not damaged. If you delete it, you can just leave the EGR valve in place or get fancy and weld it shut. However, some vehicles need the EGR valve signal for PCM calculations. In one engine I welded in an aluminum plate and the PCM was happy (SCT EGR selected off). With my newer truck I just left the EGR valve in place, happily doing nothing. Good luck with your repair and move. Last time I was in Spain I was in Albacete (with the Air Force many years ago). I was surprised at how many true blonds there were. I guess the Vikings must have went inland for some of their shore leave near there 700 years ago! |
Do you have an air lift/vacuum gauge to hook up to your cooling system to test the cooler? and its kinda hard to tell from your video but it almost seems like your cap is blowing off pressure too low, almost seems worth it to just throw a cap on. Its your cheapest option.
Re: coolant loss and tea kettle sound.
Don't confuse the moisture in the imtake with years of oil mist that accumulated in the intake to make an oily soot goo. That was the case with mine. I had partial dry soot around the egr/inlet.
Sent from my phone that somebody didn't help me get. |
next i,ll do a pressure test and see if the cap holds up to 15 psi. but maybe it is best to do a egr delete anyway,or weld some freezeplugs in it. the goo inside the intake manifold feels greasy/oil like substance. the coolant must go somewhere,..does ELC leave a trace like the gold stuff? There are no sillicates in Cat elc,how can you see it is leaking thru the cap? |
