PLEASE HELP!! EXCUSRSION STRANDED - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-23-2013, 06:20 AM Thread Starter
I have a 03 ford excursion 6.0 pwd, the problem i am having is very intermittent..i can go to start my truck and all i get is a click from the starter, only 1 click..Ican repeat the procedure 100 time and all it does each time is 1 click..i can go out the next day and try to start is and it will fire right up and run as smooth as silk..next day no start again just single click.. i changed 4 starters and even took one out of my f350 that was working fine and got the same results.i even went as far as replacing both battery's,and i also even used the jumper wire located on the fender that runs direct to the starter and hooked power to it with just a click again..I then tried jumping the starter at the starter and still just a click, i disconected the clutch fan also.. PLEASE GUYS HELP WHAT CAN THIS BE..
SHARPCURTIS is offline
post #2 of 17 Old 01-23-2013, 09:12 AM
Your starter solenoid may be weak and need to change the starter. It cold aso be weak batteries, bad cell in battery or both. Even just bad connections [corrosion]
You could also have something staying on that shouldn't be and yer haveing a voltage draw that is sucking the charge out of your batteries.
First off fully charge each battery seperately and load test seperately. Clean all connections then retest. Hook up a volt meter to the passenger battery and a amp meter around the starter wire. Observe voltage draw down and amps. no less than 10vlt.
Amps if it rolls over should be arond 500 to 600. No to a few amps if it won't roll over.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 17 Old 01-23-2013, 09:58 AM Thread Starter
BATTERY'S are brand new like i said i replaced 4 starters then also took one out of a working truck and still had the same issue..i also hooked a battery charger to the starter with a bump switch and the starter still just went click..all connections look perfect. any other suggestions
post #4 of 17 Old 01-23-2013, 10:21 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
How about the ground from the engine to the frame?
You can also check how many volts are going to the starter soenoid when you turn the key, should be a solid 12 volts if not may be a ignition switch issue.
May be a chaffing issue down to the starter?
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #5 of 17 Old 01-23-2013, 10:43 AM Thread Starter
i did an override of the ignition switch and still the same..i have 12 volts at the starter
post #6 of 17 Old 01-23-2013, 10:57 AM
whitextreme's Avatar
Check the starter cable for resistance it might be corroded inside
whitextreme is offline
post #7 of 17 Old 01-23-2013, 11:21 AM Thread Starter
i over rode all the wiring by hooking a battery directly to the starter..
i do appreciate all the comments.
post #8 of 17 Old 01-23-2013, 01:19 PM
ps_lane01's Avatar
Quoted: 2 Post(s)
Did u get it started?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #9 of 17 Old 01-23-2013, 01:22 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Did it turn-over or just click direct to the starter for this test? It seems very strange that you have the same results with many starters. I would tend to agree the starter/engine may not be getting a good ground.
The dreaded click could also be a from a weak or intermittent signal from the ignition wire or upstream to that near the ignition switch or relay. If you were to wire directly from the battery to the ignition for the solenoid, as long as your ground was good, it should crank it over.
So you would be checking the ground, checking from the starter, checking the solenoid, and finally the wiring upstream to the key switch.
There are 2 more issues at hand; do you have binding of the starter itself or is the engine bound (hydro-locked, seized)?
The simplest problem is weak batteries or battery connections.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #10 of 17 Old 01-23-2013, 01:27 PM
did you try starting in nutrual ,or moving gear shift back from park to n
catt1173 is offline
