ICP Question???
Hello to all, recently purchased an Insight CTS to help monitor my truck. I have noticed that only when I accelerate to pass or "get on it" the voltage and pressure gets high and sets of alarm... I have not seen any oil around the plug, and I have not taken it off to check inside either.....is this normal or what?
I have asked this befor also....what are some of the items you are monitoring with your CTS?...thanks the truck is an 2005 cc 6.0l |
I'll bite, but you need to be more specific or you will get no answer to your main question!
FICM (Main and Power volts) ECT/EOT temp BOOST/BACK PRESSURE psi ICP (converted pressure)/IPR % EGT (if you have a probe) Fuel Pressure (if you have a sensor) Trans Temp Any others you might want to see. |
Re: ICP Question???
Turn the alarm off......icp psi, ficm, voltage, boost, ebp, vgt%, ect, eot.
Icp pressure range is 0-4000 psi. Sent from my phone that somebody didn't help me get. |
