Help! Replaced #8 injector, Ran great for a day. Now died and won't start.
I am hoping someone might be able to help shed some light on a situation that I am having with my 2005 F250. Yesterday I took off the driver's side valve cover to replace a bad #8 injector. I reassembled the truck and it fired right up after about 20 seconds of cranking. The truck had never ran better. I drove it for about two hours that night to help work all of the air out of the system and to give me peace of mind that the repairs were 100% correct. All was well when I parked the truck last night. I woke up this morning and went out to start the truck and it fired right up and dropped into a really smooth idle. About 20 seconds later the truck started missing really badly and eventually stalled. Now all I can do is crank the truck over and it sound like it's hitting on about 4 cylinders. I have a feeling that the stand pipes may be leaking since they were removed and reinstalled when I removed the HOP lines to get to the injector. I checked the ICP pressure while cranking and it would initially spike to 2000psi and then after 1 second it would settle at 1300-1400 while cranking. Is it possible that I have a stand pipe leak? Would the ICP reading still be that high if either the stand pipe or the dummy plug was leaking? I need to get this thing back on the road ASAP, so any help would be greatly appreciated.
Thanks!!!! Paul |
Re: Help! Replaced #8 injector, Ran great for a day. Now died and won't start.
Sounds like a loose injector is allowing combustion gases in the fuel rail. Are you sure you torqued the injector down correctly and properly?
Sent from my phone that somebody didn't help me get. |
Hmm. That could be it. I was unaware that there is a specific process for torquing them down. Do you have any more info?
Torqueing the injector is very important, I know that 03 and 04 are 24 ft lb, I think later years are 26ft lb. Let me warn you now to stuff tags in all the holes to prevent anything from falling down the engine. AGOOD T40 torx bit approx 2in in length is necessary. Too often cheap ones break and the pieces are lost in the engine requiring oil pan removal, or worse engine removal to find the pieces. There are great video's on youtube. And this you, can download the coffee table book...http://www.forddoctorsdts.com/articl...icle-06-08.php
Pull secondary fuel filter, hfcm fuse, and ficm relay. Crank the truck over amd look for bubbles in the fuel housing. Sent from my phone that somebody didn't help me get. |
Thank you very much Southend!!!! I'll check for bubbles in the fuel later this evening when I get home from work. I'll post back my results.
Your welcome it's an easy check. You will want to check this out on monitoring also......Write Up: Monitoring the 6.0L PSD.
Necessary on the 6.0. Sent from my phone that somebody didn't help me get. |
Ok, so it took me a little longer than I originally anticipated to get to this test. But today I pulled the fuses and relays and watched the fuel bowl for bubbles. I only got a very few out of the bowl right when I started cranking it over. It was not a steady flow of air as I thought it would be. Is it still possible that the injector might not be sealed properly? Can I rule out a high pressure oil leak since my ICP is so high? I am planning on fixing the truck tomorrow after work so any advice is welcomed and appreciated. Thanks again!!
If you have bubbles, you have a leaking injector seal. You can google the balloon test, to isolate what bank it is coming from, unless you expect it to be #8 anyways. If it only leaks a little, the truck will crank and run like yours, until the combustion gas finally overcomes the fuel then it will die. Sometimes if you let it sit long enough it will crank back up, then do it all over again, until it finally won't run anymore.
Perfect! That is what I was wanting to know. I'll be pulling her apart tomorrow and replacing the orings, copper washer (even though they were new 4 days ago) and properly torquing the injector. Hopefully tomorrow night I'll have some good news to report! I appreciate all of your help Southend!!!
Welcome. Keep us updated.
