Installing my Fuel Injectors.... Suggestions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-20-2013, 06:44 PM Thread Starter
Send a message via AIM to gitnmybelly Send a message via Skype™ to gitnmybelly
...How can I test my fuel pump to see if its working like it should. Does a bad fuel pump mess up the injectors?
Should I change my glow plugs?
Thank for your suggestions.
gitnmybelly is offline
post #2 of 5 Old 01-20-2013, 06:50 PM
sargar's Avatar
Re: Installing my Fuel Injectors.... Suggestions
You need to check your fuel pressure...or have someone check it.
Yes, low fuel pressure is not good on your injectors.
Glow plugs and injectors are different operations as far as replacing them go.
Your post really doesn't make sense. How about being a little more clear on what you need help with.
Sent from my DROID X2 using AutoGuide.Com Free App
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #3 of 5 Old 01-20-2013, 07:13 PM Thread Starter
was just meaning since, i have this much apart (not that its a lot), is there something that would be easy to check or change while i am here.
but also wanting to know what I can do to prevent my injectors gettin F'ed up again.
post #4 of 5 Old 01-20-2013, 07:17 PM
Korx's Avatar
I wouldn't worry about glow plugs, maybe a harness. Make sure you clean out the injector hold down holes and torque the injectors to the proper spec, too much and you'll damage the copper washer.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #5 of 5 Old 01-20-2013, 09:15 PM
southend's Avatar
You should test your fuel pressure. It takes a 12x1.5mm adapter in the pourt next to the fpr cover in the secondary fuel filter housing. Here's a picture.....
If at any time the pressure falls below 46psi, the fpr updated blue spring is needed.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
