Need help! - Ford Powerstroke Diesel Forum
Old 01-20-2013, 03:38 AM
Need help!
Hello gentleman, I have a 2006 f250 an while I was at work yesterday I cleaned my EGR well this Mornin I got in my truck to come home and was driving along and let off the gas pedal and it usually "turbo farts" but today it didn't so I kept driving and then got going about 55 and I could hear like a whoosh sound coming from my turbo till I let off the pedal, any help would be greatly appreciated!!!
Old 01-20-2013, 08:26 AM
how about the performance? does it feel like it's building boost the same?
Old 01-20-2013, 09:40 AM
Need help!
Well when I'm on the highway it normally runs around 16-19ish but today it was around 10-13, the turbo spools up the same and I have the same performance, it just sounds like an air leak when my boost is around 10 and higher
Sent from my iPhone using AutoGuide.com App
Old 01-20-2013, 11:07 AM
then you probably have a boost leak somewhere. inspect all boots carefully. specifically the turbo to IC pipe boot. very common failure.
it's either a boost leak or an exhaust leak. carefully inspect for soot around the firewall, behind the turbo. you may need to look from underneath with a flashlight.
sometimes it helps to start the truck and from underneath, feel up near the y pipe bellows for exhaust escaping through crack
Old 01-20-2013, 12:15 PM
Need help!
Is it ok to drive it like that for a day or 2?
Old 01-20-2013, 01:20 PM
Re: Need help!
If you just pulled your egr, suspect those orings and gasket.
Sent from my phone that somebody didn't help me get.
Old 01-20-2013, 03:51 PM
^^good call
Old 01-21-2013, 06:43 PM
Need help!
Well I figured it out, it was the o-rings and gaskets! Now got her all fixed up
Old 01-21-2013, 08:24 PM
Re: Need help!
Thanks for the update. :thumbup:
