What is my FICM issue??
Ok,i have an 06 f250,180,000 kms....my issue is this;when i turn key halfway my Edge insight reads 48v on ficm,batteries 13 v,after cranking my FICM drops to 35-38 volts,but after truck warms up and runs my FICM eventually goes up to the required 48volts......so is my FICM shot?Even though it reads 48v after heating up?Its only after initial start that it drops....oh temps are cold up here,-7 to -20!!!Any advice would be greatly apreciated!!
toast. Send it out to be repaired.
Thats what i figured,guess i had to hear it from someone to make sure!!lol
sssshhhhhh the Canadians still think NY is part of canada.
Cranking voltage should be 10.8 or higher during the engine cranking, good strong batteries are in the high 11 volt range and alternator if OEM should be in the 13 volt range while running but will drop to high 12 volt range once everything is charged up. |
