Flex pipe/ y-pipe question - Ford Powerstroke Diesel Forum
Old 01-18-2013, 07:58 PM
Has anyone replaced one them selfs? Looking for some pointers or tips. Any help would be bad ace. Thanks
Old 01-18-2013, 08:38 PM
Yes but I am able to cheat [2] 4 ton shop jacks and 6 ton jack stands a concrete floor and a good transmission jack. I would pull the tranny back and that gave room to easyly reach all bolts. Spray liberaly with penetrant remove bolts and upper clamp.
When reinstalling hook up upperclamp first and leave manifold bolts loose tighten them last after clamp and flange are perfectly aligned and tightened clamp. Finish tighten manifold bolts. This allows wiggle room to align flange properly.
Old 01-18-2013, 08:42 PM
Illiana Chapter Director
Pull the turbo, unhook passenger side up pipe from y-pipe, remove collector bolts from drivers side up pipe/manifold connection and pull out from the top. Just did this on my truck.
Old 01-21-2013, 10:18 AM
Which y pipe did y'all use? I have found the stock one an eBay store and then there are a few others out there. Where did y'all get yours?
Old 01-21-2013, 10:24 AM
I'm just using a stock one.
Old 01-21-2013, 11:00 AM
Where did you get all the gaskets and which ones do I need?
Old 01-21-2013, 03:13 PM
There's only one gasket. It's the one between the passenger side up pipe and the y-pipe. I got it from Ford.
Old 01-22-2013, 11:13 PM
Just ordered all my parts, wish me luck.
Old 01-23-2013, 01:33 PM
Re: Flex pipe/ y-pipe question
Good luck.
Sent from my phone that somebody didn't help me get.
Old 01-23-2013, 06:21 PM
just make sure you leave all connections loose before you get that turbo flange mated and clamped.
