coolant leak..head gasket or egr delete? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-17-2013, 10:39 PM Thread Starter
Ranger5.0l's Avatar
Like the title says I have a coolant leak that seems to be coming from the engine valley and running down the passenger side of head and block then dripping onto trans cooler lines before hitting floor steady drip for hours after truck is shut off. Just wonder what it might be any thoughts?
Ranger5.0l is offline
post #2 of 3 Old 01-18-2013, 04:42 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 555 Post(s)
Garage
Take a close look at the heater core 3/4 line, the control valve is on the pass side valve cover and the valve itself is possibly the culprit.
Are you sure it's coolant? and not condensate from heat/air coil.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 3 Old 01-21-2013, 03:51 PM Thread Starter
Ranger5.0l's Avatar
Turned out to be the o ring on the egr delete pipe changed it out seems to be fine for now..kinda strange though only leaked after coolant pressure started to drop after shutting truck off but not while running
