cracked Heads - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-17-2013, 07:46 AM Thread Starter
cracked Heads
Both of the cylinder heads for my 6.0 are cracked , and after some exhaustive Google searching I found my options are a new set from tousleyfordparts.xxx @2k + S/H, a set from odessa cylinder heads @1500 for new castings and S/H. But both of them have the inductive hardened valve seats and mostlikely will have the same problem that i have now..... CRACKED HEADS........ The other option I found is UCF Machine Shop - Ford Diesel 32-valve head teardown and analysis. they install all new valves and any needed parts, replace all the intake and exhaust valve seats with a hardened seat, replace all the valve guides with iron spiral reamed valve guides S. B. International ... Tech Topics. Price $2450 if my cores are bad. The only catch is that they o-ring all the heads that they do ??????? I have mixed feelings about the o-ring of the heads but I like the everything else they do.
2005 F250 Crewcab Short bed
K&N Air filter
MBRP 4" Turbo Back (no kitty & muffler)
ARP Stud's
Upgraded turbo up pipe & EGR Pipe flex tube.
EGR Delete
Dozers RR
CCV mod
SCT Tune By Elite
Coming soon .... modified Engine oil cooler, Mad turbo werks hybrid, 175 sticks from
What good is a truck if you can't smoke....
MasterO-6.0 is offline
post #2 of 16 Old 01-17-2013, 07:52 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
I can order you OEM?
2000-7.3L is offline
post #3 of 16 Old 01-17-2013, 04:57 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
Don't o-ring your heads, it's not necessary
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 16 Old 01-17-2013, 07:33 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Go with Odessa you won't be disappointed. Myself along with many others on here have their heads on our trucks and run them without any problems. For the price you can't beat it and they include free shipping both to you and for return shipping on the cores.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 16 Old 01-17-2013, 07:40 PM
Term3's Avatar
Quoted: 2 Post(s)
cracked Heads
Do they only have remanufactured heads? I was trying to see on their web page where their "updated" heads are.
Sent from my iPhone using AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 16 Old 01-17-2013, 07:52 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
No they have both, remanned heads are $650 each with a 2 year unlimited mile warranty and same shipping rates as above.
New are $700 each with a 5 year unlimited mile warranty.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 16 Old 02-21-2013, 04:17 PM
Sno-Mow's Avatar
I put a new set of OE on and cracked in 9200 miles. Looking for options and keep running across the Odessa heads. How are they holding up? I put 40k miles on a year and need to make sure no issues before dropping ANOTHER $1500 on this truck!
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
post #8 of 16 Old 02-21-2013, 04:58 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
I have put 55 psi of boost to my Odessa heads and OEM head gaskets MANY MANY times and run the chit out of my truck and they are holding up just fine.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 16 Old 02-21-2013, 06:34 PM
Sno-Mow's Avatar
How many miles on them?
2003 F250 6.0l
Blizzard 8611PP
Sno-Mow is offline
post #10 of 16 Old 02-21-2013, 06:37 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
So far around 5000 ABUSED miles lol.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
