I sent in an oil sample for the first time. It had been 6,000 miles since the oil change at the dealer. It was Motorcraft 15W-40. My first oil change since purchasing this truck used from a Ford dealer. Well, I got a call from the oil analysis lab, and obviously, he didn't have a lot of good news.
First off, he said I had 5.5% fuel dilution in the motor oil. I told him that I idled the engine a lot, and he acted like 2% fuel dilution is common for 6.0L Powerstrokes, but not 5.5. And while Ford claims that up to 8% dilution is okay (According to the lab) but he finds that 8% is obviously very bad news. So did I do this idling the engine a lot? He says that this amount of fuel brings the oil down to around 10W-30. Do I have a bad injector? The other thing is there was some silicon, but when he asked me if I used silicone sealant for the oil filter, I had no clue (I have never changed it). He acted like I should check the air filter, too, but it was new 6,000 miles ago, I believe. He said the wear looks good, but maybe the fuel diluted signs of engine wear! |
Anyone had fuel in the oil? Warranty
You think it's covered by the warranty?
How many miles on the truck?
Sorry, I should have said. I bought it used with 79,000 in February. It now has just 85,000 miles. I think it's still covered for certain engine components, hopefully like an injector seal or something.
yup your engine warranty should still be good. with a $100 dollar deductible
I have a 2005 F250 6.0 and I changed my oil (for the first time,I bought the truck back in August,used.)today,The oil smelled like it had fuel in it , although I don't know the percentage.The truck has 77200 miles.This is my first diesel.
Two questions about how you took your oil sample. Did you take it hot and did you take it midstream? If you took it cold it will always show a high percentage of fuel dilution.
oil test
Yah, I read another member that was freaking cause of a high fuel content -- but it came down to he drives the truck short distances quite often and it doesn't completely warm up
Also, 6K miles might be too long of an interval and it all depends on how you took the sample... |
