urgent help NO BOOST - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-16-2013, 05:55 PM Thread Starter
Been working on a customers 05 6.0 and had to remove the turbo to replace the rubbers hose to the egr cooler. Line was leaking. Installed all new orings on everything. New oil feed gasket and oil feed oring and orings on drain back tube. Truck made good boost before I took it apart. Now I have nothing. The turbo sat on the work bench for about a week. In the time it sat could the unison ring on the varible vane have seized to the housing? Or could the actutor have gone bad? I cleaned the exhaust back pressure sensor. I'm at the end of my patience with this truck. This truck has been so half assed in the past its like every corner I turn I find ****ty work or failing parts your guys help would be greatly appreciated.
Thanks,
Nathan
1993 Black Cobra
1996 Mystic Cobra
1997 F-250hd ccsb 7.3
1997 F-250hd eclb 7.3
1999 Electric Green Cobra (11.75 at 116 N/A)
1999 Black 4v Whipple Lightning
2000 Cobra R #282
2003 F-250 7.3
2004 Black Mach 1 (10.39 at 132)
1997F-250HD is offline
post #2 of 20 Old 01-16-2013, 06:06 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Make sure your Mass Air Flow sensor is connected and check the rubber hose that goes from the intake manifold up to the MAP sensor.
dhanna6powerstroke is offline
post #3 of 20 Old 01-16-2013, 06:16 PM Thread Starter
Map sensor is good. And truck has no mass air.
1993 Black Cobra
1996 Mystic Cobra
2000 Cobra R #282
2003 F-250 7.3
post #4 of 20 Old 01-16-2013, 06:25 PM
Mod Newbie
Quoted: 20 Post(s)
There's no way the unison ring seized while sitting off the trick for a week and unlikely the VGT solenoid went bad. You check the VGT connection? I've seen the tabs break and not keep the connector in place and cause a bad connection. Any codes?
post #5 of 20 Old 01-16-2013, 06:33 PM Thread Starter
No codes. One tab is busted off the the vgt but the other one clicks and holds it on. Truck starts and idles great just when u drive it has zero boost.
1993 Black Cobra
1996 Mystic Cobra
2000 Cobra R #282
2003 F-250 7.3
post #6 of 20 Old 01-16-2013, 06:37 PM
Hate to ask this but it is easy to get frustated and over look the easy simple things. Have you checked for exhaust leak at the up-pipe? Are all of the boots and CAC tubes tight?
Sent from my GT-P5113 using AutoGuide App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #7 of 20 Old 01-16-2013, 06:38 PM
Mod Newbie
Quoted: 20 Post(s)
Even though the black hose from the MAP sensor to intake is hooked up, have you checked the hose for splits or cracks? Can you hear any hissing or air rushing under the hood when running or trying to accelerate?
post #8 of 20 Old 01-16-2013, 06:47 PM Thread Starter
I'm going to triple check everything again tommorow and then check back in with u guys. hopefully i just overlooked something simple.
1993 Black Cobra
1996 Mystic Cobra
2000 Cobra R #282
2003 F-250 7.3
post #9 of 20 Old 01-16-2013, 08:09 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Stick a bobby pin or needle or something small into the copper barbed fitting that sticks up out of the intake manifold that the MAP hose connects to. Sometimes they get clogged up and need cleaned out and can cause a misreading of no boost through the MAP sensor.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #10 of 20 Old 01-17-2013, 02:16 PM Thread Starter
Checked everything again when i got home. Did clean the map sensor port out to check.
Took it for a drive it mad about 10psi and is very sluggish on making it. Still got a feeling it is the unison ring sticking. No codes yet.
1993 Black Cobra
1996 Mystic Cobra
2000 Cobra R #282
2003 F-250 7.3
