Engine died, now no start - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-16-2013, 09:54 AM Thread Starter
Angry Engine died, now no start
While driving on the interstate, the engine shut down, no warning, or codes. I have had trouble with IPR clogging in the past, engine cranks fine, just won't fire. Scanner says no hop to fire injectors. I have commanded the valve open and closed, and it appears to be moving. My question is, if its clogged, would that cause a no start? I have had the valve replaced three times now. 2006' f350' new injectors, egr delete, new turbo, new oil cooler, new exhaust, edge with attitude cts. Any advise is appreciated.
Astroman4180 is offline
post #2 of 12 Old 01-16-2013, 09:57 AM
Nally7.3Powerstroke's Avatar
What was the IPR getting clogged with so much? 3 times seems a littls strange, if it was metal I would almost say your pump was coming apart??
Nally7.3Powerstroke is offline
post #3 of 12 Old 01-16-2013, 10:01 AM Thread Starter
Not metal
When I got truck, it had been neglected.... The oil filter had come apart from not being changed when needed. There was a large amount of crude built up in side, it is going away after many oil and filter changes, but has still caused a lot of grief. When the oil cooler was changed, we did replace the screen as well.
post #4 of 12 Old 01-16-2013, 10:01 AM
95powerstroke5spd's Avatar
Sure sounds like a HPOP being your IPR was so dirty...
1995 F250 Ext cab Long box 7.3 DI Turbo Diesel 5 spd 308,000 mile TS 6 position chip.....Is currently without an engine
1996 F250 Ext cab Long box 7.3 DI Turbo Diesel Auto 210,000 mile Stock except for the wheels.....Looks like a crushed beer can at the moment :/
2006 F250 Crew Cab Short box 6.0 DI Turbo Diesel Auto 5 spd on the column 218,000, EGR delete with up-pipes, FICM tuner, 285/70/17 Mickey Thompson Baja MTZ rubber,
95powerstroke5spd is offline
post #5 of 12 Old 01-16-2013, 10:26 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
A clogged screen will cause a no start. I'd remove and inspect the IPR and then reinstall it and then do a HPO air leak test.
dhanna6powerstroke is offline
post #6 of 12 Old 01-16-2013, 12:43 PM Thread Starter
HPO air test
Anyone a link, or easy instructions on how to check the HPOP with air? Thanks
post #7 of 12 Old 01-17-2013, 01:20 PM Thread Starter
Running again
OK, so we pulled the IPR valve, small tear in screen, some trash on it as well, but not neaqrly as bad as I would have thought. Replaced it with a new valve and she fired right up. This is another one out the window. Not sure where the trash is coming from, or how much more there is..... I dont want to keep replacing this thing every 5-6k miles..... Thanks to everyone that helped.
post #8 of 12 Old 01-17-2013, 02:05 PM
I thought a plugged screen is a very good sign of failed/failing pump ?
post #9 of 12 Old 01-18-2013, 06:50 AM Thread Starter
From all I have been reading, if the trash or debris is metal, then YES, the pump is failing most likely. Mine is not metal, just sludgy oily crude. I was told the truck went over 50,000 without an oil change, and at one point, the filter had come apart. I have changed the oil every 4000 for the last twenty now in hopes of cleaning it out. I'm a little scared of trying to flush it with something, in fear it may break too much loose at once, and then I will be chasing cloggs everywhere. Any advice from anyone else on this issue is truely appreciated.
post #10 of 12 Old 01-18-2013, 06:54 AM
ZMANN's Avatar
Quoted: 1597 Post(s)
just to clarify your running motorcraft filter and oem cap correct ?
We Miss you Ronnie
ZMANN is offline
Tags
hpop bad , ipr , no start
