Thinking HPOP problem, - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-14-2013, 06:43 AM Thread Starter
I have a 2005 Ford with a 6.0 diesel. I am thinking the HPOP is going out. It will loose all oil pressure and sound an alarm when i take my foot off the gas and it goes to ideal. Get back into the gas and the oil pressure will rise again. Am I thinking correct and is the a good mechanic in Oklahoma that will not charge a arm and let to replace.
thanks,
Travis
hogman1979 is offline
post #2 of 2 Old 01-14-2013, 10:49 AM
Powerstroke Techie
Doubtful, not impossible, but doubtful. The more common trucks that would lose oil pressure on the gauge were the early build trucks 03-04, with the cast iron pump cover. there was a check ball on the feed side of the pump that would fall out and cause a MASSIVE low pressure system oil leak the LPOP couldn't keep up with.
What I would do first, is check the base engine oil pressure with a mechanical gauge, to rule out a sender/wiring/cluster issue.
After you've done that, report back.
The gauge in the dash measures the oil pressure in the low pressure system, not the high pressure system.
If your truck loses HP oil for any reason, you will likely experience rough run/stalling issues.
Hope this helps. I've changed a LOT of oil pressure sensors on these engines for this exact issue. Unhook the connector at the oil pressure sensor on the top of the oil cooler (single wire) and see if it's leaking oil into the connector as well.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
