surging
Just got engine back in and it is surging while driving. More so under wot or load. Doesn't surge at idle. If I hook up th AE and close the vgt and drive it doesn't surge at all and with the vgt open it surges a little. So is it the vgt selonoid? Im only getting about 20 lbs boost max. Turbo was cleaned and put back together with antisieze. Cant find any exhaust leaks. I will list all work done.
Arp head bolts Oem head gaskets Arp rod bolts. New main bolts. Egr cooler delete. Blue spring upgrade. Resurfaced heads New injectors. All new gaskets and o rings. New lp oil pump. Updated dummy plugs and standpipes. Reman hpop Updated stc Cleaned turbo unison ring and vanes. All new bearings. Clevite Everything cleaned 3 times. Im sure I'm forggeting something lol. Last edited by stangconcepts; 01-13-2013 at 07:13 PM. |
probably is a VGT solenoid, I've seen this a few times
