2003 6.0 Crank No Start - Ford Powerstroke Diesel Forum
Old 01-13-2013, 02:13 PM
My truck stopped suddenly while driving down the highway. IPR readings were at around 77% while cranking so I suspected a sticking IPR. The truck still does not start after replacing the IPR. I replaced the ICP about a month ago.
I plan to tear into the HPOP tomorrow. Any ideas on what could be the problem?
Thanks in advance.
Old 01-13-2013, 02:16 PM
MAD - Modification Addict
Feedback Score: 7 reviews
HPO leak....
Old 01-13-2013, 02:19 PM
Originally Posted by Tuscany View Post
HPO leak....
Thanks man, any detail on where this leak could be?
Old 01-13-2013, 02:45 PM
The hpop, standpipes, injector orings, hpop oil hoses. What is your actual icp reading while cranking?
Sent from my phone that somebody didn't help me get.
Old 01-13-2013, 02:49 PM
Illiana Chapter Director
How many miles?
Old 01-13-2013, 02:51 PM
I don't remember and I can't get a reading right now because I drained my batteries from long cranking. I'll get a reading once I charge the batteries.
Old 01-13-2013, 02:53 PM
Originally Posted by dhanna6powerstroke View Post
How many miles?
165,141 miles
Old 01-13-2013, 02:54 PM
There is a hpo air test you can perform, and this test for the hpop.....DIAGNOSING A 6.0L HIGH PRESSURE PUMP!
There is a check ball that can pop out of the hpop also.
Could be a leak but if it's the original pump with that many miles, I'm gonna say the pump is junk.
Old 01-13-2013, 03:02 PM
There is a hpo air test you can perform, and this test for the hpop.....DIAGNOSING A 6.0L HIGH PRESSURE PUMP! - Ford Powerstroke Diesel Forum
I'm going to perform the HPOP test tomorrow. If the check ball pops out will the entire pump need to be replaced? How is the HPO test performed?
